SOURCE: Fridge not cold
ice build-up on the back wall indicates a defrost issue, check the defrost items. check the defrost timer, the defrost heater and the defrost thermostat, if you need more details let me know.
SOURCE: Haier HVT 12ABS fan runs, but fridge does not get cool
Hello warmfridge
happy to assist you,
You said,
We've had this wine fridge for about 3 years now, and all of a sudden it stopped getting cold. We still hear the fan
turn on and all appears to be running smoothly but it remains room
temperature inside. Does anyone know how to fix this? I have no
experience, but would like to try rather than buy a new one. thanks!
1. You may need to add freon.
2. It may have a faulty thermostat.
It seems you need hands on service!
Our site has good companies in the repair directory.
Bless you,
please rat me here before you sign off.
Thank You
SOURCE: freezer working fine but fridge wont go cold!
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
SOURCE: Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from
Haier places, but I just took the motor out and took it to an appliance
repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
