20 Most Recent
Haier HRT02WNC Compact Refrigerator Questions & Answers
My fridge doesn't work anymore
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
As the weather is getting warmer for many people their freezer and/or
refrigerator do not work right because of a dirty condenser coil...there are
also many other things that can go wrong. If you are hearing a clicking or
buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start
trouble shooting your unit...and something that you can do rather then calling
a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
It won't get cold
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br />
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br />
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then…</span><br />
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Will not run at all when plugged in
More than likely, it needs a new control board. It takes about 5 minutes with Google to locate a new board. Runs about $30 (including shipping.
Warning, requires knowledge of soldering to install this board.
No, I had no way of testing the board. However, since the part is cheap and it came up almost immediately when I started searching, pretty safe to assume that's the problem. Yes, replacing the board solved the problem for me.
The control board is located behind the sheet metal on the back of the refrigerator.
I purchased my replacement board through www.repairclinic.com
Item # 1223802
It will not get cold, everyting turns on, fans-light
you need a new rtc overoad contactor on your units compressor which is located in the rear of the unit,remove the spring wire that secures it to the compressor body and unplug and reverse procedure to install
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Noise
Freon "boils" when compressed and pushed through the evap. causing cold. Sometimes after time you can hear it making the boil sound. There is really no way to fix it. Well... There is a way to fix but the price you would pay to fix it; you could turn around and buy a brand new freezer! GOODLUCK:)
