Whirlpool WTW4800XQ Washer Logo
A
Anonymous Posted on Jun 28, 2011
Door locked&spin light blinking & won't open - Whirlpool WTW4800XQ Washer
Anonymous
Level 3:
Brigadier General:
  • Master 6,277 Answers
  • Posted on Jun 28, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
6277
Questions
0
Helped
1026625
Points
20216
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
2helpful
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
2helpful
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Red security activation light on dash won't stop blinking. When starting engine alarm goes off and have to use key in doorlock to disarm. Have replaced 50 amp fuse under hood but still no success
Had same problem not to long ago~~~~ I have to check all 4 doors to be sure they are locked mainly the back 2 and then I went around to all 3 door locks & locked and unlocked a few times each... it was on passenger side when my light finally was deactivated... hope this helps you.. I haven't had any problems since ;0)
Lid locked &spin lights blinking won't open
CALL UR TECHNICIAN 2 RUN A CHECK ON THE MACHINE PANEL
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
