The flashing green light is the in use indicator on the base. Click the scroll button down on the handset to show the call list, then press the x or secrecy button, then press the tick or menu but to confirm, the call list is now empty and the green light has stopped flashing, You need to repeat this for each handset until complete
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then tap the Find button 7 times. On the handset: remove a battery hold the menu key and refit the battery screen says SW VERSION press up arrow key until screen shows REGISTER CLEAR press menu press menu again and wait for OK to appear remove a battery and refit
Registering the XD5500 handset. Then register the handset to the base as follows: Hold Find button on base unit until you get two beeps On handset: Press menu Scroll to register Press menu Scroll to Register Base Press menu Press 1 Wait When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note: If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a fault and if it is less than a year since purchase the retailer should change it for you.
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
To Mrs Sue Groom, You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500 http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
hi just want to help others as desciption aint complete above Registering a BT Freestyle 2200 handset 1. If there is a handset in the base remove it whilst you are registering the new handset. 2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing. 3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-. 4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000 5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
