20 Most Recent
Xact Communication XG2200 Cordless Phone Questions & Answers
How can i delete messages on my BT Studio 1500?
go into menu, go to "play message", scroll down to "all messages" press the tick button, when the messages play press X (secrecy) button.
you have to delete them one by one
hope this helps
1/10/2012 7:17:13 PM •
Xact...
Answered
on Jan 10, 2012
I have idectx1i twins cordless
make sure you are using the line cord that came in the box with the telephone as this won't work with a different telephone's cord.
Is there a trident symbol flashing in top left corner? if so, press menu, down to setting, press ok, down to handset setting, press ok, down to register, press ok, enter pin 0000, press ok and at the same time press and hold the handset locator button on the base station for 10 seconds.
4/5/2011 11:22:59 AM •
Xact...
Answered
on Apr 05, 2011
Please could you tell me how to delete all my
Hi there i am trying to fix my phone too. To delete the message via the handset use the tick button to select your menu choice and the volume up and down to scroll through the messages. Listen to messages and delete them all using the x secrecy button. Hope this helps.
3/28/2011 7:01:26 PM •
Xact...
Answered
on Mar 28, 2011
Lost comunication
I solved this problem with a RESET of the handset.
Instructions from the Philips website:
Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept).
1. Unplug the mains of the base station.
2. Remove one of the batteries of each handset.
3. Put the batteries back in and re-plug the mains of the base station.
6/6/2009 4:55:14 PM •
Xact...
Answered
on Jun 06, 2009
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
4/22/2009 7:03:16 AM •
Xact...
Answered
on Apr 22, 2009
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
2/11/2009 6:27:20 PM •
Xact...
Answered
on Feb 11, 2009
Recharging phone constant beep
When misplaced in the charger the xg2200 beeps, are you sure the phone is placed correctly?
please let me know.
Good Luck
9/3/2008 4:55:52 PM •
Xact...
Answered
on Sep 03, 2008
GE 900mhz model 26936GE2-C
Sounds like a defective battery or low battery.
1. Have you replaced the battery?
2. Have you changed the channel?
3. Have you dropped it?
Answer these few questions and we'll see if we can figure it out.
Let me know.
3/2/2008 8:35:36 PM •
Xact...
Answered
on Mar 02, 2008
Handset has No link to base
I
was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the
AC and phone cord from the base station and plugging both back it, then removing and replacing
the handset to regenerate the security code.
11/19/2007 7:13:13 PM •
Xact...
Answered
on Nov 19, 2007
