Are there different ringtones available for the NEC Electra Elite? if so, how can I change it. we have several phones in the same office and want to differentiate the ringtones.
Look for the Elite Attendant User Guide Also call your vendor for the password SET RELOCATION MODE Set/Cancel using the Access Code: 1. Press the Feature key. 2. Dial Set Relocation Mode code 84 .
Feature - Redial and then select the button you wish to change. Enter a 1 (not sure what that is for) and then the new extension. To verify that the button has changed, hit Feature and then the soft key to see if the extension is different.
You have to be on the root phone or "first phone". To check various phones -Hit {feature} 4. Should display 100= TEL 01. Once on the first phone then use {feature} 9 #. Time will flash at top of display and can be adjusted.
If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
You must access system manager in the system. Call your office and get the main greeting than dial 632 for system manager. You must know the password to get in. than listen for mgr options. than listen for opening greetings. Remember 1=yes 2=no. LDTSNJ.com
On an NEC Elite you must enter system programming to change the name of the extensions. Unless you have a PC connection to the system this is somewhat complicated. If you would like me to step you through the system programming, please contact me @ 850-326-0394.
