I got 1 modem (pldt dsl) cdrking wireless router and 2 desktop pc. i can connect to the internet in my host pc but unable to access the internet on the 2nd pc. when enabling the LAN on the 2nd pc it says "cable unplugged". there's no light when LAN cable is connected (even a steady light). there's a light on the the port of the router where the pcs are connected to, the one comes from the 2nd pc is just a steadt light. it worked the first time i ran the setup wizard but now, it's just a ****. i made sure i installed everything. physical connections are ok too. what am i doing wrong? please help. anyone? thanks
Connecting laptop/computer to wireless router If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver. 1. You need to sign up with an Internet service provider. 2. Connect a LAN cable from your computer to the DSL or cable modem 3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions. 4. Install Internet Explorer if it has not been done. 5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then - To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
It could be a faulty wiring connection from the ethernet cable to the RJ45 (plug). Exchange the cables from your PC1 and PC2 to confirm it. If that worked then you can either buy another set of cable (just make sure to try it in the store first). Or if you have a wire cutter especially made for ethernet cables, then just cut the RJ45 and replace it with a new one. You can buy those on CD-R king too.
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Connect the lan cable from the dsl modem into the first port on your netgear router .. make sure your dsl modem is on PPPoE mode so that it autoconnects.. Now just connect to your wireless router via your pc interface.. *Do add a network key to your wireless network to avoid unwanted access
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem,192.168.1.1 is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
assuming you have a wireless router, make sure you have purchased the correct one, as cable and dsl routers are different, as cable modems need to be connected to the router via a cable and dsl normally have a modem that can't be connected to a router, and you will require a modem/router.
You can only share a wireless connection when the line comes directly to the router and not through a pc, as the pc with the connection will have to always be on.
