I've added a new HHD to HP 380 G4, but the Windows server 2003 couldn't see it .. then I create a new logic m using array 6i. after that I could t boot from the old HDD .. how can I rollback to the normal state
Use the HP Smartstart CD and configure the with array with 2 arrays and 2 logical drives. The first with OS array on RAID 1 (2 drives mirrored). The second array on RAID 5 (3 drives minimum).
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
HP SmartStart CD x32
The utility to use to set up the ML370 g3 server is the SSCD (smart start cd) this is a guided installation cd that will help you set up the array, install drivers and diagnostic utilities and after that will request the windows cd so that you can finish the installation. instructions: 1. download SSCD from here 2. extract the zip file 3. burn the ISO image to a cd 4. boot the server to the cd 5. choose from the main menu the option "Deploy server" 6. follow the wizard
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E" ACU
Are you able to get into the array configuration and make sure the logical drive is still intact? If the logical drive is gone, then your partition may be lost. If you are able to recover the logical drive in your array (which you should be able to if the RAID5 striping was stable) then you should be able to recover your data. You can get into the array configuration during the boot up sequence.
As of now you can
Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally . It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced . You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
