20 Most Recent
HP Compaq ProLiant DL360 G3 Server Questions & Answers
Hi, My HP Proliant DL360
Check and Clean Processor FAN and all cooling Fans inside the server.
Check the cable connectivity of the CPU Fan on the M/B.
Update server with Latest BIOS firmware.
11/28/2011 10:57:00 AM •
HP Compaq...
Answered
on Nov 28, 2011
Hi
My HP proliant dl360 G3
From my experience, this is an indication that your fans need replacing. If your system manager is working properly, at night if your system is not use much, the manager will put the system in a low state of operation, almost like hybernation. When a request come in to 'wake-up' the system, the fans do not spin fast enough to cool your system properly thus the errors.
Replace the fans, recheck your settings in system manager making sure the manager software is monitoring the cooling and not the os. This should solve your issue.
Good Luck
C2Solutions
1/18/2011 6:42:43 PM •
HP Compaq...
Answered
on Jan 18, 2011
I want to install an
You firstly have to make your usb key bootable just google instructions on how to do that.
Set the boot order in the bios to boot from it and then transfer the image to the usb key and install from it.
11/18/2010 9:23:44 AM •
HP Compaq...
Answered
on Nov 18, 2010
No puedo instalar Small Business
Si el sistema operativo no reconoce tus disco, y ya has creado un arreglo nivel 1 o 5 y en la bios si puedes ver los dicos, el problema es posiblemente que necesites cargar los drivers de la controladora. Si puedes ver el modelo de la controladora (visible en el post) dirigete a la pagina de hp.com/support escoje el pais USA para que tengas acceso a todos los drivers, descargate el ultimo driver de tu controladora y cuando este instalando windows presiona f6 para cargar los drivers
8/30/2010 3:17:35 PM •
HP Compaq...
Answered
on Aug 30, 2010
"Base System Device" error in HP DL360 G3 c dual Xeon 3.2;
Hi there Jim,
You will require the HP ProLiant Integrated Lights-Out Management Interface Driver for Windows Server 2003.
You can acquire this
here. Let me know of any problems.
Please do not rate this reply unless I have solved your problem or your reply will not be returned to me.
Regards
nLinked
8/6/2009 10:11:12 PM •
HP Compaq...
Answered
on Aug 06, 2009
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum
that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum
and never told PC model sure.
so windows sounds work in the test in control panel
yes !
the, MP3 is complex, it can be from high data rate, source
and will not play unless converted .
one thing to try is use this free app
called Audacity
https://www.audacityteam.org/
then play it or convert it
or buy a USB sound dac that can decode any sound file on earth
or learn to test you PC first
windows sounds work
then in google type
simple MP3 sound test
https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/
works good above so your MP3 is no good or wrong bit rate.
if fails yours only , buy new DAC USB dongle now it plays them all
if windows sounds are dead the sound driver is missing
or on a server there is no sound chips oops. buy the DAC dongle.
if only 1 MP3 fails out of 100's find a better one or buy a DAC.
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways.
BE SPECIFIC.
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
