The TS55 is a DVC subwoofer that can be wired for either 4 ohms (voice coils in series) or 1 ohm (voice coils in parallel). The appropriate wiring depends on the amp.
If the amp is stable at 1 ohm, wire both positives and both negatives to the matching amp output terminal (parallel) as shown in Wiring Option #1.
If the amp isn't stable at 1 ohm, connect a jumper between the positive on one voice coil and the negative on the other voice coil. Then connect the remaining positive and negative to the matching amp output terminal (series) as shown in Wiring Option #2.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=1&woofer_imp=3
