SOURCE: LG LCD turns itself on
try setting the default time on the timer to 00:00 see if that helps Did to one person and they said all was good. Good luck
SOURCE: pltv3250
do you get audio but no video? if the blue light is not glowing on the power supply.... its gone bad... the vents tend to clog with dust, overheat and burn out In 2 1/2 years I've gone thru 2 of them
SOURCE: Military time
I have the same problem. The clock changed to military time after we experienced a power failure. I have tried to correct it by holding down the "Alarm Set" button and hitting the "On/Off" button at the same time. It works while the buttons are pressed but immediately reverts to milirtary time. Any other suggestions?
SOURCE: TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
SOURCE: clock is in Military time...can't change it back...
If you call Dacor they will talk you through the solution but you have to have another person ready to turn the breaker off while someone is pushing a button. I have contacted them and am trying to get the instructions emailed.
Dacor Toll free: 800-793-0093 have model # ready
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Press the Right Arrow button and then use UP/DOWN button to select Manual
Clock
Press the Right Arrow button and then use Left arrow/Right arrow button to select either the year,
date, or time option. Once selected, use the UP/DOWN button to set the year,
date, and time options.
Press EXIT button to return to TV viewing or press MENU button to
return to the previous menu.
On the time option, you can select itt to 12Hour or 24Hour format. OK.
