True GDM-12FC Refrigerator Logo
Anonymous Posted on Jun 16, 2011
I decorate cakes and put them to firm up in the fridge. I have a lot of condensation build up on the icing while its in there. Is there an adjustment I can do to stop this?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
73
Points
You need to make sure your door is closing tight and the gasket on the door is not torn
  • Anonymous Jun 17, 2011
    Gasket on door is like new. Seals tight,door is closed.
2answers
Our Hotpoint Future Frost free FZS175 alarm is beeping and it is defrosting. Can we fix this ourselves?
Check the freezer: If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
https://www.appliance-insurance.co.uk/appliance-insurance-articles/6-causes-beeping-fridge/
What are cake balls?
Cake balls are round balls of cake covered with icing or some kind of decoration. It's similar to cupcakes but round in shape.
Feb 28, 2013 • Baking
2answers
What should fridge temp be for cakes and cooked meats?
the ideal temp in a fridge is +5C,no colder,or your veg will spoil.
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
2helpful
Ge side by side profile. freezer works fine, all
Hi!
First of all you need to clean the coils (condenser coils under the unit or evaporator coils inside the freezer). The coils inside could be iced over because of failure of defrost system. Now check that the condenser fan under the fridge is working properly. Check that the fan in the freezer work which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temperature control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.
My first guess would be the defrost timer. You can manually turn it to engage the defrost cycle and observe whether or not the defrost heaters come on. Now use a hair dryer to speed up melting the ice when there is lots of ice buildup. Most timers are 24 hour timers. It will turn the defroster on every 6 or maybe 12 hours depending on the model.
Before testing the defrost heater, unplug the refrigerator to avoid an electrical shock hazard.
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
2answers
Motor freezes up
the issue is not with the motor to be honest you have probably wasted money buy a new fan motor ,
the fan only stops working when ice builds up and forces it to jam , the ice builds up as the defrost heater is more than likely faulty - very common issue on all uk samsung rs21 models ,
to rectify the fault totally its recommended to replace 4-5 components that operate the fridge cooling /defrosting system - sounds complicated but its really just 1-2 hour job for a skilled competent person
have a look at this video , also check the youtube chanel for same guy , there are lots of info on samsung uk american fridge freezers
3helpful
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
1helpful
Maytag skybox
Problem may be the PCB board (w/Sensor) for the Flipper Door. It has a tendency to become corroded due to condensation that can build up by the door. Maytag replacement part number is 11001182. Part is hard to find. I was able to get one after much searching. Within 3 days it was out of stock again.
To combat the condensation (and ICE build up on the rear main board), turn the fridge down to half and keep the front lights off as much as possible. You may want to play with the settings a little depending on the area of the country you are in (dry Arizona as opposed to wet Washington State) but you shouldn't have to go below half.
Even though the lights are flouresent, they still throw off a lot of heat which causes condensation. The fridge runs longer to combat the heat so the added moisture freezes in the back (where the cooling elements are) and the condensation builds up in the front where the sensor and heat source is. It's cool enough in front to hinder evaporation and because the fridge runs longer you don't get that defrost period (if you will) in the back that regular frost free refrigerators or freezers have, thus the ice build up. This will greatly reduce condensation but may not get rid of it all. The front door is not to well insulated. Hope this helps.
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
