Hello, you want the unit tilted back in the window somewhat, the unit should not be level because this will cause the wateR to settle in the front of the unit and drip. Also, if the unit has a drain plug remove it so the water can drain out of the unit.
You might need to purchase a window unit mounting kit, here is a linkhttp://www.apwagner.com/index.php?main_p...
I figured I needed to tilt it back but it only fits in the window 1 way and does not allow for it to be tilted back. Any suggestions?
