Uniden BT-108 Bluetooth Headset Logo
Posted on Jun 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 11, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1950
Points
Anonymous
Level 3:
  • Master 436 Answers
  • Posted on Jun 15, 2011
Anonymous
Master
Level 3:
Answers
436
Questions
0
Helped
188704
Points
1420
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
How to pair my bb curve to uniden BT112 bkuetooth
You need to put the bluetooth into pairing mode.
tell the person with bt112 bluetooth to pair with you.. their will be a thing that pops up on your phone that says enter pair code just put 1234
1helpful
2answers
I am unable to access any of the blackberry services on my bold 9700. my carrier suggested that as the phone has been unlocked that i need to reflash? can you advise
Try to unlock your phone using blackberry bold 9700 unlock code network from your original sim card. If your phone already unlocked you didn't need reflash process, blackberry unlocked phones can use any other network sim card whenever you put that sim card on your phone.
1helpful
2answers
I have a Blackberry Bold The lock icon is on the bottom right but then it goes topassword. I've tried what I think the password is but no luck. I don't remember it. What do I do to get it?
There is only one option left to unlock your blackberry phone, but it will erase all your previous data. Type any password until you fail 10 times, it will make your blackberry bold unlocked from old password. You can try other option to unlock blackberry but the result will be same, you can't save your data, that's feature of RIM security system. Sounds like double side sword huh?
1helpful
2answers
Blackberry bold 9700 Bluetooth problems
Many quirky behaviors for these devices are fixed every time a new software version is released.
You might check that you are using the most current system software for your BlackBerry Bold 9700 Smartphone.
The latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
Bluetooth Connectivity between Nuvi 710 and Blackberry Bold 9000
get the firmware update from the Garmin Updater. It fixes the connectivity issue with the BB 9000
I've got a bluetooth wireless keyboard that I originally bought for my Palm TX. My company has now treated me to a Blackberry (bold - 900) and I'm sure I should be able to install the right driver to the...
Blackberry and Palm are 2 totally separate OS's. Palm uses Palm OS which is based on an HP platform, and Blackberry is it's own OS's. Their not cross-compatible
12helpful
3answers
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
