20 Most Recent Blackberry Curve 8350i Questions & Answers
The phone is probably locked to your supplier.
Blackberry Curve... | Answered on Feb 17, 2018
Go to blackberrymep.com, there you will find all about blackberry unlocking .
Blackberry Curve... | Answered on Feb 14, 2017
For the I-phone, contact I-Tunes and they can track it... When getting your phones back I have an app called where's my droid... which gives coordinates for my phone if lost or stolen... You have a password and can only activate this application from specific phone numbers - which I have pre-entered and know to call from...
Older phones and phones with out a similar application... I would speak to your carrier but don't see it happening. Sorry about the bad news:(
Blackberry Curve... | Answered on Sep 09, 2016
Don't worry I will help You!!!!!!!!!!!!!!!!!!!!!!!! You can unlock the mobile from the Security Lock using the Master Reset Code,You can get the Master Reset Code at http://www.unlocking4u.com/unlocking-services/rs6wp6/ and Unlock the mobile. You Check Master Reset Code for your model in the list...
Blackberry Curve... | Answered on Jul 10, 2015
From the Applications Screen: Options> Security Options>General Settings> Hit the Blackberry Key> Wipe Handheld.
Blackberry Curve... | Answered on Jan 24, 2015
From the Applications Screen: Options> Advanced Options>Select the Application> Hit the Blackberry Key>delete and reboot the device
Blackberry Curve... | Answered on Jan 23, 2015
You need to add your email to your blackberry to get emails. This can be found under email in the settings section. You wont recieve bbm messages unless you have another blackberry user in your bbm list. This is done by either giving out your pin number or entering the pin number of another blackberry into your phone.
Blackberry Curve... | Answered on Jul 28, 2014
You need to put the bluetooth into pairing mode.
Blackberry Curve... | Answered on Jun 15, 2014
Hi Akira,
This error can be caused by a few different things, including faulty third party software. Have you downloaded any apps lately?
Make sure you have BlackBerry Desktop Manager installed on your computer, then unplug the battery from your BB and make sure that it is not connected to the computer. Start App Loader, then plug the USB cable into your phone. Once the phone lights up, wait to see if it starts up and if the PIN appears on your computer (in App Loader). At that point, plug in your battery. The software should load, and you can remove the third party app. If you don't think it's an app causing the problem, you can try using the repair option in the Desktop Manager. Let me know how it goes.
Ensure that the SIM card is installed and is active. Then try going online using data (not WiFi), and make a phone call. The phone will tell you that radio is off, and then it will ask you if you want to switch it on. Say yes, and it should work again.
Does it just say Error normally it says a number??
Blackberry Curve... | Answered on Mar 01, 2014
This happened with my phone but it was Error 102 i couldn't solve it my self so if i was you, go to a phone shop :)
Is it locked to your network? And you want to use to any other network globally? If yes, then you need to unlock your mobile according to the network you reside , Its a paid service. first find out your mobile phone IMEI number. You can find this by typing in *#06# and then hitting the enter o rsend key on your Iphone . This number is completely unique to your phone and will be used to generate or calculate an unlock code for your mobile.Then the unlock code here http://www.theunlockspot.com/unlock-your-phone/rs10wp2/ using
unlock code specified in it you can proceed unlocking your mobile.
Blackberry Curve... | Answered on Feb 20, 2014
You cant turn on to the network means you needed to unlock your mobile according to the network you reside ,What you will need to do is first find out your mobile phone IMEI number. You can find this by typing in *#06# and then hitting the enter or
send key on your phone . This number is completely unique to your phone and will be used to generate or calculate an unlock code for your phone . Keep in mind this only works with GSM or SIM based phones and not CDMA ones. Get the unlock code here
http://www.theunlockspot.com/unlock-your-phone/rs10wp2/ using the unlock code specified in it you can turn on to the network you reside..
take the battery out start charging it with no battery then take the charger out then put your battery back in then the charger
Blackberry Curve... | Answered on Feb 17, 2014
Reinstall OS
Blackberry Curve... | Answered on Dec 13, 2013
Reinstall the operating system
Download the facebook app from the app world and run it.
Try a battery pull and if it doesnt work try leaving it for charge for a couple of hours and then do a battery pull again :).
I hope this works
If you want to remove the subsidy lock from your blackberry 8350i mobile phone,I would suggest you to get an unlock code from
Mobileunlocksolutions.com at reasonable price.
Blackberry Curve... | Answered on Dec 12, 2013
Blackberry Curve 8350i Logo
Popular Tags
134 questions posted
Top Blackberry Cell Phones Experts
raysaw
Andrew Taylor
Andrew Taylor
matt
matt
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Blackberry Cell Phones
Most Popular Question
unlock blacberry 8350i
  • Cell Phones
