Ctm HS 890 4 Wheel Heavy Duty Power Scooter Logo
Posted on Jun 14, 2011
Need owners manual for A ctm hs 740 mobility scooter.
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Nov 06, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
1684
Points
5
Go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
  • Robert Mckay
    Robert Mckay Oct 23, 2014
    Requier manual for740
  • Robert Mckay
    today please
Luis Navarro
Level 1:
Habit-Forming:
New Friend:
  • Contributor 24 Answers
  • Posted on Aug 31, 2016
Luis Navarro
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
24
Questions
0
Helped
12092
Points
84
Here is were youll find the owners manual for your HS-740
http://www.ctmhomecare.com/Home/ProductDetail?pid=HS-740
1helpful
Need wiring diagram for ctm hs-588 mobility scooter
Here is the manual. I am still looking for the schematic. the manual does have a god troubleshooting section. http://scooterland.net.au/wp-content/uploads/2015/08/User-Manual-HS-589.pdf
The horn on my CTM HS-740 is not working. How do I check it out?
Remove the top tiller console and check connections from membrane horn switch to horn. Test for voltage to the switch with a voltmeter. Check for voltage to the horn when the switch is pressed. These horns are inexpensive and easy to replace by splicing the wires and hot gluing the new horn inside the cover.Hope this helps
1helpful
Need a controller for a mk1 CTM HS 740
Hi try this +44 800 096 1296. good luck try this phone number they might have youre controller .............+61 3 9329 3666...... Cheers
2helpful
2answers
How do I get a wiring diagram for CTM 850
Hi there is a PDF instruction download type in CTM850 mobility scooter schematic. INCLUDES HS-890 or U can get in touch with www.ctmhomecare.com.they might b able to help .good luck
Where can I download a technical and repair manual for a C T M HS-360 MOBILITY SCOOTER 4 wheel mfg 2003 and parts list?
go google and type in workshop manual for ctm mobility scooter model hs-360
the first page has a pdf version for down load and the site is ctm mobility scooter-ctm home care product .inc.
further down the sites is a pdf version download parts manual as well -- ctm home care hs-360 parts
1helpful
Why no lights, indicators, horn or charge indication?
hi, now i could be wrong but some models of CTM mobility scooters had a fuse on the tiller circuit board located under the tiller cover...
Be sure to remove a battery connection before looking ...
Regards
Rob
2helpful
Intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
Top Ctm Health & Beauty Experts
john h
Rob Hill
Rob Hill
Arnie Burke
Arnie Burke
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
