20 Most Recent
Ctm HS 890 4 Wheel Heavy Duty Power Scooter Questions & Answers
How do I get a wiring diagram for CTM 850
Hi there is a PDF instruction download type in CTM850 mobility scooter schematic. INCLUDES HS-890 or U can get in touch with www.ctmhomecare.com.they might b able to help .good luck
My scooter wont go and
hi, there is a fault finder at the back of the manual, 5 flashes means the drive motor is not coonected, check that the freewheel lever at the back of the scooter is in drive then turn off and on again with the key, hope this helps. Bill
Jus bought rascal 325 scooter for elderly neighbor, found some loose connectors, and wires, made repairs, charged batts, drove down to neighbors, sat a few days, now wont go, but lites, horn, turn sig
Unconnect drive motor and check voltage drive motor might need replaced
Where will i get a replacement wig-wag for my Vigor mobility scooter. The old one is damaged.
You would probably have to contact a service tech for the product. This is usually a service call item unless the chair still works and the arm is just broken. You might be able to just get the arm. Some manufacturers require the whole assy to be replaced. That would require a tech unless you want to do the repair yourself. The manufacturer would not warrantee the part if you broke or damaged it while doing the repair yourself. They would for a certified tech.
