Hi from your description it sounds like your TV is turning on since the red light stays on and it's not blinking. In that case I would say that since your TV is on but you are not geting a picture then one of your Zustain boards is bad. the first thing I would do is to check the fuses since you said you already did that and they are fine you can check that their is high voltage getting to your Zustain board. Their is a sticker on the screen that tells you how much voltage they should be geting. Usually about 220 volts. If you are getting voltage to both bords you can check to see if the heat sinks are getting how. They are supposed to be hot so if they are not that board is bad. If all else fails you can try replacing both boards. To order parts you have to get the part numbers from the actual parts. You can get parts from www.interliquidparts.com
