20 Most Recent Panasonic VIERA TH-65PV500 65 in. Plasma Television Questions & Answers
This fault is most likely caused by the plasma panel itself, which would be prohibitively to replace. I suggest contacting Panasonic service and tell them about your problem. I have known Panasonic to be very good in the past, often still helping out even when the item is out of warranty.
Panasonic VIERA... | Answered on Feb 05, 2018
Unplug it, wait a minute and replug it. Also check the settings and see if it changed.
Panasonic VIERA... | Answered on Jan 04, 2018
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Panasonic VIERA... | Answered on Jul 10, 2017
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Panasonic VIERA... | Answered on Apr 24, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Panasonic VIERA... | Answered on Apr 03, 2017
Loss of power from power supply. Usually bad power supply.
Panasonic VIERA... | Answered on May 04, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Panasonic VIERA... | Answered on Dec 19, 2015
I had the same problem with a Panasonic Viera Plasma TC-P50S3 with 14 flashes. I used an ohm meter tocheckcontinuity of the boards inside, starting with the power board (power to TV off). Check YouTube for videos on how to do this. The SC card showed a fault (It was reading close to zero ohms on both pins. I could find no one who supplied SC boards and could only find repair kits. Repairing a circuit board is outside of my ability, time and tools. I found a place online to send the SC board in for repairs. $65 plus shipping. I was getting $350 "ballpark" quotes from Panasonic authorized TV repair shops. If none of this works for you, there are TV salvage companies who will pay you some cash and pick up TV from you. You can also sell it on craigslist for salvage parts or part it out separately. The various boards seem to cost around $100 each and you likely have four or five in your TV. At least for my TV, the parts don't seem to be out there, so there is a demand for the salvageable parts.
Panasonic VIERA... | Answered on Nov 08, 2015
I had the same problem with a Panasonic Viera Plasma TC-P50S3 with 14 flashes. I used an ohm meter tocheck continuity of the boards inside, starting with the power board (power to TV off). Check YouTube for videos on how to do this. The SC card showed a fault (It was reading close to zero ohms on both pins. I could find no one who supplied SC boards and could only find repair kits. Repairing a circuit board is outside of my ability, time and tools. I found a place online to send the SC board in for repairs. $65 plus shipping. I was getting $350 "ballpark" quotes from Panasonic authorized TV repair shops. If none of this works for you, there are TV salvage companies who will pay you some cash and pick up TV from you. You can also sell it on craigslist for salvage parts or part it out separately. The various boards seem to cost around $100 each and you likely have four or five in your TV. At least for my TV, the parts don't seem to be out there, so there is a demand for the salvageable parts.
Panasonic VIERA... | Answered on Nov 05, 2015
There are many things that can cause this red flashing light such as..
  • Fan Failure
  • Latched Thermal Overload
  • Burnt bulb (for Projections)
  • Power Supply issues
All which will require the attention of a qualified, professional tech. Definitely contact Panasonic if under warranty, contact your extended warranty underwriter, or contact a local service repair shop that is experienced and qualified to work on your TV. Panasonic will be able to provide you with a list of qualified service repair shops in your area, you can also contact their Plasma Concierge service online for advice.
Hope this helps!
Panasonic VIERA... | Answered on Oct 24, 2015
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Panasonic VIERA... | Answered on Aug 24, 2015
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
366 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VIERA Panasonic
  • VIERA Panasonic
Most Popular Question
funai 32 inch plasma tv
  • Televison & Video
