20 Most Recent Panasonic TH-37PX50U 37 in. HD-Ready Plasma Television Questions & Answers
Check the cable line thats attached to the bad set on another set side by side. If the other set still has no channels your going to need to trouble shoot or replace the tuner control bad and the tuner assy.
Panasonic... | Answered on Dec 30, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Panasonic... | Answered on Jan 22, 2016
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Panasonic... | Answered on Dec 15, 2015
use the menu button on the tv its self. it will let you go to all the menu setting and tv signalk settings.
Panasonic... | Answered on May 13, 2014
This type of fault to most Plasma Displays are due to its energy recovery section circuit.
Panasonic... | Answered on Feb 05, 2013
Well on the Tv itself the vol up and vol down and the channel up and down will help you do this there may even be a menu key which is a nice feature but if not try pushing both the up and down vol or the up and down channel buttons at the same time. if not that try pushing different combinations you get it don't let that electronic win....lol
Panasonic... | Answered on Dec 07, 2012
Must check tv carefully for tv images burn in problems,plasma tv have that problems alot.This tv have major issues are power shutdown alot and power supply will not sustance and flashes it power light indcation.Have to unplug awhile like an hour replug back to get tv to work again.If u have chance to used it like 5 hour a day like for a week have warrenty for a week for a return it and get 95% of ur money back.Used it for a week about 5 hrs every day no power shutdown and no power LED light indication flashes i whould buy it.
Panasonic... | Answered on Aug 28, 2011
Hello!
You should check first if the IR sensor (Infrared sensor) of your TV is still working. It is beside the pilot lamp to where you point the remote to control your TV.
Use the camera of your phone or your digicam to check if IR sensor is still working.
Looking on the IR sensor of your TV via the camera of your phone or digicam, if the IR sensor is working you should see it illuminates. If not, then IR sensor or its sensor board is deffective.
The best way to fix it is to bring it to a certified technician to replace the whole IR sensor board.
Good Luck!
Panasonic... | Answered on Jun 12, 2011
Hi cewilso,
Make sure that you have a good connection from your cable box. If the static lines didn't appear in Video mode then the problem is in the reception. Hook up properly the cable connection and ensure a good source of signal from your cable provider.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Panasonic... | Answered on Feb 21, 2011
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Panasonic... | Answered on Dec 18, 2010
try moving the image with the adjustments.... wont work? change the 100uf 200volt filter just ahead of the flyback.
Panasonic... | Answered on Nov 11, 2010
tv will not turn on, blinks 10 times. this is the second time in 3 years
Panasonic... | Answered on Apr 23, 2009
probably your cable box, request another one from your provider
Panasonic... | Answered on Mar 29, 2009
Panasonic TH-37PX50U 37 in. HD-Ready Plasma Television Logo
32 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
panasonic th 37px50u horizontal lines
  • Televison & Video
