There a 2 wire harness to the motor in the door. Pull it off and put a test light across the leads. Don't use a voltmeter, because you can get 12 volts from a bad switch with too little current to power the motor.
Bearing bad in motro or possible bad capacitor. Hard to say unless you know how check capacitor and fan motor. Price on cap replacement about 150 Fan motor abot 250 to 300 with new cap. Ask for free estimate before you commit. Russ
You may have afan motro going out out they do rattle and then quit and then do it again. Call service tech for free estimate on repair. When the fan motro goes out everything quits. Compressor overheats Everyhting melts. Rus
Most common problem is a broken regulator. If you press the button to open or close you should hear the motor click. If nothing is heard then your switch could be bad, wiring could be bad, motor could be seized.
