Centurion Systems: (you will have to C&P the full URL shown below)
There are only two systems of door opener, XTrac and RDO.
Manuals can be found here: (Page down until you see the appropriate section.)
http://www.centsys.co.za/?q=con,114,Product Documentation
Note that the driven shaft requires periodic lubrication.
Although most systems should be lubricated with Molybedenium disulphide grease (applied manually), I find that a small amount of spray oil every 6 months works wonders.
The shafts can and do aquire dust, and this can cause the load on the drive mechanism to exceed limits. If lubrication does not solve the problem, then you may well have a drive unit failure, requiring repairs by the manufacturer.
Note that NO lubricant should be applied to the steel door guides.
The manuals are of a different series, thus are unhelpful. I need someone to provide me with information on how to reprogramme my control unit. The door is raising and lowering using the manual button on the unit, however, the light is blinking which indicates the setting is incorrect. Is there someone who knows how to reprogramme the control unit?
