20 Most Recent liftmaster Garage Door 1/2 Hp Questions & Answers
Liftmaster Garage door Opener. I need a manual site for a garage door opener with this part # 41a5021-d
Question edited for a lot more clarity. Question moved form Cars and Trucks category. The part number you stated is the logic board on a Liftmaster Garage Door Opener. No, the cable is supposed to spiral wound around that pulley. It is connected to the spring which takes the weight of the door. You need the model number to find the manual. https://www.google.com/search?q=part+%23+41a5021-d ..
8/5/2023 1:23:59 AM • liftmaster... • Answered on Aug 05, 2023
Hi there. My coromaster 2000 has
Recategorised from Vacuum cleaners to 'at least' a Garage Door Opener category. This unit is only available in South Africa, and we are a North American website which is probably why help was not forthcoming in 2017.. There is some general help here though for setting travel limits. https://www.google.com/search?q=coromaster+2000+has+lost+its+limits ..
7/8/2021 9:04:12 PM • liftmaster... • Answered on Jul 08, 2021
2answers
Garage door making clicking noise
internal drive gears are going. take cover off and take a look
11/29/2019 7:47:42 AM • liftmaster... • Answered on Nov 29, 2019
My Garage door are having problem in opening and i am looking for an experience garage door repair professional. Any suggestions?
If you want a professional Garage Door Repair service then, I would like to suggest you always prefer online professional service. Because they provide the best service at an affordable cost and also have experienced workers to fix all types of issues regarding garage door.
7/11/2018 11:03:50 AM • liftmaster... • Answered on Jul 11, 2018
Liftmaster with both L.E.D.s are lit and steady but still won't close.
Depending on the model the travel needs to adjusted, some models have a force adjustment. Call LF customer service the will help you.
1/9/2018 7:30:37 PM • liftmaster... • Answered on Jan 09, 2018
Garage door does operate at
If these problems started immediately after a lightning storm, the printed circuit board is probably damaged. Contact a garage door service company (check the phonebook) for diagnostic support.
12/2/2017 1:32:46 PM • liftmaster... • Answered on Dec 02, 2017
When I open my garage door no lights come on. I changed out both lights with new bulbs, still no lights when I open or by manually clicking the Lights on the wall opener
Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
8/2/2017 4:38:45 PM • liftmaster... • Answered on Aug 02, 2017
HOW CAN YOU CROSS LIFTMASTER MODEL NUMBER AND HAVE BELT
Thayst a logic board #.. What model # is the operater.. 8165 8500 8550 etc??
10/2/2016 10:46:38 PM • liftmaster... • Answered on Oct 02, 2016
Will not open or close with remote
9/21/2015 1:41:45 AM • liftmaster... • Answered on Sep 21, 2015
My garage door won't go down and keeps blinking 10 times.
first, hold the wall button down and do not let up and the door will close for you. second, one of the wires to your sensors is loose, broken or shorted out by a staple thru the insulation. you can bypass the sensors on a temporary basis while you find the issue, by jumping the sensor connections at the motor.
8/13/2015 4:48:29 AM • liftmaster... • Answered on Aug 13, 2015
3answers
The garage Remote control was working normally at
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
7/10/2015 4:20:47 AM • liftmaster... • Answered on Jul 10, 2015
Garage door works with remotes but not with wall pad.No led on pad. Woke up to a open garage door. Install is about 2 years old
check all wires,someone may have cut them to break in
6/17/2015 12:19:02 AM • liftmaster... • Answered on Jun 17, 2015
When pressing remote, there is a short electrical hum, but the door fails to move. Up or down.
Sounds like the opener has opened to far and the trolley is now jammed against the stop bolt.
5/26/2015 11:12:49 PM • liftmaster... • Answered on May 26, 2015
I live in North Dakota
all it is is the motor that needs replacing save urself some money and check inside for the model number of the motor and order a new one for around 50 dollars beleive it or not there are probably 20 to 30 things that use the same motor
5/19/2015 7:24:34 PM • liftmaster... • Answered on May 19, 2015
Garage door will close, stays shut for a few
The opener is closing too far. On the side of the opener, you should see 2 white knobs, recessed into the side. Using a flat blade screw driver, adjust the close knob (closest to the door side of the opener), anti-clockwise until the door will close gently on the floor.
5/12/2015 7:29:34 PM • liftmaster... • Answered on May 12, 2015
3answers
Garage door light blinks but doesn't stay on
Three blinking lights & door won't close by Candi (Winston-Salem, NC) Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit. I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed. If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned. 1) Check that the operator has power. The green lights on the sender and receiver should be lit. 2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by mis-alignment or something blocking the beam. Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally. http://www.linearcorp.com/pdf/manuals/LCO75.pdf NOTE: If the receiver's red light remains off, check for: 1) Dirt on the receiver's lens, 2) Sunlight shining into the receiver's lens, 3) A short in the safety beam wiring (from staples or at the operator terminals). http://www.linearcorp.com/pdf/manuals/LCO75.pdf
2/18/2015 9:36:36 PM • liftmaster... • Answered on Feb 18, 2015
One senser is green one is amber
Make shure that the green and amber lights on the sensors are solid and not flickering ! most of the time when a sensor is not aimed exactly at the other sensor it will give a weak signal and not allow the door to come down , we call this a constant hold down since you have to physically stand and hold the wall button down for the door to go down , Your sensors are made up of a receiver and a sender , The sender always will be lit but the receiver may not receive a strong signal since it,s beam may not be pointing at the sender ...check to see if that's the case, also look for cob webs around the sensors since that can also trigger this , another thing that people always do is put brooms and shovels near the sensors and wind up getting a bad signal because a shovel is in the way of the beam , Check these things and you should have success in fixing your problem ! Hope this helps Sincerely Glenn
2/7/2015 5:40:03 PM • liftmaster... • Answered on Feb 07, 2015
How much is gear kit for 1/2 #41A2817?
Gear kits can be purchased for chain drive machines from any of these 3 brand names ...Liftmaster/sears craftsman /chamberlain / All 3 of these brand names are manufactured by Liftmaster the worlds largest maker of garage door openers and related parts ! You can purchase a gear kit on ebay for around $30 or less depending on the seller ! If you go to garage door parts sites it will be slightly higher so your best bet is EBAY , The gear kit only requires the main gear and sprocket housing that attaches with 3 screws , just remember after the gear is installed that you run the motor co that the trolley starts in the door down position otherwise you risk having the trolley smack into the opener , this is crucial for any travel adjustments that are made later! Hope this helps you ,sincerely Glenn
2/7/2015 5:23:12 PM • liftmaster... • Answered on Feb 07, 2015
2answers
Door suddenly will not close without holding the
It definitely sounds like a sensor problem. In normal operation, one sensor will have an amber or yellow light on, indicating power to the sensing circuit. The opposite sensor should have a green light on. If the yellow light is not on there is no power to the circuit due to a broken wire or circuit board failure. If the green light is not on or is flickering, the sensors are not aimed at each other or the light path is blocked.
1/20/2015 5:24:13 PM • liftmaster... • Answered on Jan 20, 2015
liftmaster Garage Door 1/2 Hp Logo
185 questions posted
Top liftmaster Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • liftmaster Building Materials
Most Popular Question
when open garage door no lights come
  • Building Materials
