iHome Clock Clock Radio for iPhone  iPod (iP9BR) Logo
Posted on Jun 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My iHome keeps resetting the date, alarms, presets... everything! I fix it to how I had it, then two days later it resets itself again to January first, 2008..
Anonymous
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Jun 05, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
152
Questions
Helped
21438
Points
492
Check that the power supply cable isn't broken. It could turn itself on and off by itself. If it has a battery backup use that.
How do I set the time on a KADIO KD-3806 digital clock
Earlier FIXYA question:
sachin_arane
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
2helpful
2answers
I have lost the instructions on how to set the time and date for a digital multi clock GH120A, please tell me how
https://m.blog.naver.com/PostView.nhn?blogId=mobile_app_top&logNo=220570562627&proxyReferer=https://translate.googleusercontent.com/translate_p?hl=en&prev=search&sl=ko&u=http://m.blog.naver.com/mobile_app_top/220570562627&depth=1&rurl=translate.google.com&sp=nmt4&xid=25657,15700022,15700186,15700191,15700256,15700259&usg=ALkJrhgAAAAAXRePT_E1IEH3FJYm7TS9LAEefyLAgoL5
Visual Think December 16, 2013 23:09
Add neighbors Body Other Functions
For the GH120A / GH-120A,
Multi stopwatch / table clock / stopwatch / stopwatch timer, etc.,
Just have an alarm function, a small digital watch with a stopwatch function.
This watch,
I think there are so many users that I can often see at someone's house, and I think it will be difficult to find the manual later.
sometimes,
I do not think it's inconvenient for someone to read this manual.
Below is the manual.
1. Button Description
- MODE : Each time the button is pressed, the sequence changes as follows.
; Current time ? stopwatch ? alarm setting ? time / day / calendar setting ? current time
- RESET : When the stopwatch function is activated
; STOPWATCH STOP - RESET STOPPER TO 00:00
; When the stopwatch is started - On the screen, the first stop is displayed one second, and the second stopwatch is running internally.
(It can be useful when measuring 1st and 2nd records when running 100m)
At this time, press the START / STOP button and press the RESET button again to display the last second
- START / STOP
; When the stopwatch function is activated - Start or stop the stopwatch function
; Time display function - Date display
; When setting alarm or time - Function to adjust set value (time / minute increase, date increase, etc.)
- Back button
; Press once to activate the backlight for 3 seconds (keep lighting while pressing)
- Back round switch
; When the switch is turned off, the alarm sound and the button sound are turned ON (ON character display state is ON)
; When the switch is raised, the alarm sound and the button sound are turned off (OFF character is OFF)
2. Feature Description
- current time / date / day setting
; Press MODE button 3 times in time display mode
? If you press START button,
? Pressing the RESET button (minute blinking), pressing the START button increases the minute
? Pressing the RESET button (time flickering, pressing the START button increases the time,
Change AM / PM after 12 hours
? Press RESET button (date blinking), START button
? Pressing the RESET button (blinking the month), START button
? Pressing the RESET button (blinking day), START button
? Press the MODE button to complete the setting.
- Stopwatch (stopwatch)
; Changed to the stopwatch function with the MODE button pressed once (0:00:00) in the time display mode.
? Press the START / STOP button to turn the stopwatch on and off
(However, if the RESET button is pressed during the stopwatch operation, the stopwatch stops, but internally,
The second clock is still running, press the START / STOP button once,
When the RESET button is pressed, the second stopwatch is stopped)
- Alarm function
; Press the MODE button twice in the time display mode (the flashing hour part appears on the screen)
? Timed by START / STOP button
? Pressing the RESET button (blinks for a minute)
? Split by START / STOP button
? Press the MODE button to enter the time display mode (create a bell shape on the screen)
; Disable / set alarm function
If the RESET button and the START / STOP button are touched simultaneously, the bell disappears and the alarm is canceled.
(Press again the RESET button and START / STOP button again to display the bell shape and activate the alarm function)
- SNOOZE
; When the alarm sounds, pressing the RESET button completely turns off the alarm,
; When you press the START / STOP button (bell blinks)
; After the alarm is turned off for a while, the alarm sounds every 4 to 5 minutes.
; To turn off the alarm completely, press the RESET button.
- Hourly time signal notification
; It is a function that sounds once every hour,
; While in the time display mode, press the MODE button while holding down the RESET button.
; When pressed,
; If all the day of the week display is visible on the screen, the time notification function is ON,
; OFF state if no day of the week is displayed on the screen
- Backlight function
; Press the round button on the back once to activate the gauge for about 3 seconds (press and hold to continue)
- 12/24 time system change
; Press MODE button 3 times (second blinking)
? Press the RESET button twice (at the time)
? Press the START / STOP button once to alternately display AM / PM / 24 hour display with increasing time
? Press the MODE button after setting is completed.
This concludes the GH120A User Manual (manual) posting.
Trouble alarm every 12 hours
Here is a link to instructions to access web based control of alarm unit.
http://www.smarthome-products.com/productspecs/DSC/TL-150-Manual.pdf
Hopefully you can log into it and find where to set time server, or at least set time/date.
1helpful
My ihome want charge my iphone 4
Your iHome may be an older model with an the wrong charge type. Different iPhone / iPod generations use different charge voltage with iPhone requiring a higher voltage than your iHome gives. My suggestion would be to get an adapter that should fix the problem.
21helpful
5answers
KADIO KD-3806 Model watch. How can we set date and time.
Nov 12, 2010 • Watches
25helpful
2answers
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 • Watches
RCA model DRC8335 Loosing the date and time
That will be a problem from the text side of the broadcast, the clock is set from the text transmission, ( in other words a problem from the transmitter ) possibly due to digital switchover or work on the transmitters. One possible solution would be to turn off auto clock setting, and/or auto summer time adjustment.
80helpful
6answers
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
2helpful
3answers
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Top iHome Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
