Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Savin SDC 103 has an SC-172 call service error. The copier was given to me, it only has 7800 copies on it. The error showed up after they moved it.
Anonymous
Level 2:
  • Expert 263 Answers
  • Posted on May 24, 2011
Anonymous
Expert
Level 2:
Answers
263
Questions
0
Helped
132766
Points
586
That code is related to the scanner unit.
Probably after they move the machine the lamp went out of position.
I advise you to see the all scanner; Lamp, Mirrors, White plate...
2answers
SC 590 on a Savin 917. Looks like I need to replace the drum. Bad Copy Qual.
sc 590 is an exhaust fan motor error
the fan could be failing as for the copy quality the pcu will probably solve that problem
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
RICOH MP4500 SC 390 DISPLAYS WHAT TO DO
Hello.
That error is related to TD sensor error.
I advise you to call a trained Technician
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
3helpful
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My SAVIN 2575 is giving error code sc820, any idea what the problem is ?
Unfortunately, I've never seen this error, so I can't give you much help beyond what the code means and the possible solutions that the service manual provides...
SC820:
Self diagnostic error: CPU - Unexpected external error or interrupt occurred.
• Controller board defective
• Software defective
The manual indicates this is a "C" type code, so this should not be displayed on the OP panel, only logged in the SC history in the machine.
We have a Savin 2545 copier. We received an error message SC 726. Can you give me some idea what we need to check?
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
1helpful
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
1helpful
2answers
I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Top Savin Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Ngoro
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
