Vacuums Logo
Posted on May 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why can't I find the instructions or manual for SALTON YOGURT MAKER thermostat controlled? Model #GW5 I would like to print it.
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on May 23, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
528092
Points
3536
You should be able to use this manual for your Yogurt Maker:
http://www.scribd.com/doc/21228176/Salton-Yogurt-Maker-YM9-Manual
I could not find a GW5 Model made by Salton. Please check your model number again and I hope this helps.
2answers
I found a salton tweety and sylvester waffle maker, but there are no instructions. The light just stays on all the time when plugged in. How do you know when the waffles are done?
Try letting it warm up for at least ten minutes. Then add waffle batter and leave closed for about five minutes and check the waffle. If it is way over done try three minutes other wise adjust your time in thirty second increments. You should have great waffles in three or less tries.
Good Luck,
Gil Shultz
Jul 19, 2011 • Vacuums
I have an old yogurt maker, the miracle yogurt maker model K-8, and I have lost the instructions. It is round with a plastic lid and holds 7 glass jars with lids. Do you need to put water in the bottom...
Go to www.Google.com and copy and paste in this phrase: operation manual miracle yogurt maker model K-8
There are two ways of going ahead from here. The first way is to open the file. If you do this, remember it may take a while and your computer will appear to be froze. Just hang in there, depending on your download speed, it will arrive. Second way, When you click on the .pdf link, your second choice will ask to save to disc. You will need to save to file. After a few minutes, the manual will be in you Downloads folder called Yogurt Maker Manual .pdf
You should be able to search your computer for this if you don't know where your downloads folder is. Hope that helps, I don't know your level of expertise on a computer, I don't want to treat you like you don't know anything. Computers are difficult for us older folks. If you do need more assistance, Please check back.
Dec 20, 2017 • Vacuums
2helpful
I have found my old Slton Yourt Maker...Thermostat Controlled Model, GM-5 25 watts...but no instructions. Have read many blogs...am I safe to simply put in the ingredients, plug in and wait for 6-10 hurs?...
Basically, heat your milk to a boil and then cool until it reaches the "add starter" mark on the spoon thermometer. Add starter, and then you're good to go.
Found the manual, it's in .pdf format.
http://www.divinemind.biz/files/Salton%20Yogurt%20Maker%20GM-5%20manual.pdf
This should help you out. : )
Mar 13, 2011 • Vacuums
I have a Salton Yogurt maker and I need new caps to the jars.
I'm not sure of your exact model, but you can find several postings of these on ebay similar to the one at the following link:
http://cgi.ebay.com/Cuisipro-Donvier-Yogurt-Maker-Jars-w-Lids-Set-8-NEW-/110428356023?pt=Small_Kitchen_Appliances_US&hash=item19b60afdb7
Hope this helps!
Feb 28, 2011 • Vacuums
I was given an old Salton YM4 yogurt maker, but it has no directions. Can you help me?
Click HERE for an older manual, it should suffice for what you need. Sorry it took so long, but I only found this after another came looking for the same thing
Joe
Jan 09, 2011 • Vacuums
50helpful
Owner's Manual for Salton Yogurt Maker Model GM5
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large. It may be easiest to print it, they scanned it in sideways:
http://kitchen.manualsonline.com/mdownloads/79d6ebbc-08f6-43bb-b0d9-4d97db052580.pdf
Oct 13, 2010 • Vacuums
Salton EX 20 manual
Hello:
I had the same problem, I needed the instruction manual for Salton EX-20 Three for All. Searching the net I found the following answers:
Sep 05, 2010 • Vacuums
What is the ratio of yogurt culture to milk to make yogurt? I have misplaced the instructions to the euro cuisine yogurt maker.
Usually only a very little culture is needed to be added to milk to obtain good yogurt. But if you can add 100ml to one litre milk , it will be fine.
Aug 31, 2010 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
