Price Pfister Ashfield Single Control Lavatory Faucet ... Logo
Posted on Nov 27, 2017
We are installing a Price Pfister Ashfield Collection 808 Series. When installing the shower handle, it does not seem to go against the trim plate. There is at least 1/2 grap. According to the picture on the box, there is not a gap. Should there be that gap? Is there something that can be done to correct it, if not?
rayc588
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 40 Answers
  • Posted on Dec 30, 2017
rayc588
Contributor
Level 1:
Cheetah:
Answers
40
Questions
Helped
16784
Points
65
The valve body was installed too close to the front of the wall. Open up the wall and set it back per the instructions or live with it.
1 Related Answer
Anonymous
  • 1902 Answers
  • Posted on Feb 13, 2009
SOURCE: Price Pfister ashfield collection shower single lever.
This sounds like a proper with your water heater. If you just installed this new shower head. First take it off and make sure that the hot water valve is opening fully if that checks out then go to the water heater and make sure the pipes check out ok and also that the heater is ok. Try putting a water heater blanket on it. Also try getting some pipe cover and cover the hot water line so on really cold days or not you will have warmer water
How do I get the handle off
if it is a single handle or mixer tap
look under the handle and there will be a plastic plug ( probably red/blue ) pull that plug out and there will be a hex screw that will unscrew and allow the handle to come off
Pfister hanover 808TMKK hot water stopped working why?
Sounds like the cartridge went bad Home Depot Cary's some but not all of them
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_87482045335a4757
1helpful
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Re: single handle lav. Ashfield: cold water flow is fine; hot water flow severly restricted. Have disconnected supply tube and flow is fine into a bucket so it is not a problem with valve or supply...
I have the same problem with my Ashfield faucet.
I am going to contact Price Pfister and try to get a new 'cartridge'.
On another note, my Ashfield towel rings are also broken. The connection where the two pieces meet is so weak it cannot handle daily use. I am going to bring this up with Pfister as well.
It doesn't seem like Price Pfister has very good products.
1helpful
How doi i get the cover plate off to get the valve out
http://www.pricepfister.com/www/ImageAssets/mirror/model/bath/catalina/catr89-7eb/ex-808-01.pdf The cover plate is held in place with part #972-300. That part has threads on the inside like a typical nut. Grab firmly ann twist counterclockwise.
2helpful
I have a Price Pfister Model no. 808 DK00 single handle bath tub/shower faucet. I am only getting hot water coming out when the handle is turned on. This problem just started. It was working fine for about...
It's likely that you have some sediment that has accumulated in the cold water valve and has clogged it. The model number you have cited above is only for the trim (rather than for the valves behind it). Assuming that you have a Price Pfister valve, they don't have built in filters, so you're probably going to have to either clean or replace the valve.
1helpful
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Swaping Pfister Shower leaver handle
it must be the same model number,most models come in different colors and styles.
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
