Life Fitness 95Te Treadmill Logo
Posted on May 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen reads "Unit immobalized
Anonymous
Level 3:
  • Master 1,116 Answers
  • Posted on May 16, 2011
Anonymous
Master
Level 3:
Answers
1116
Questions
0
Helped
528090
Points
3536
Here is the manual for your unit. See the section on Managers Configuration specifically custom message on page 37.
http://jp.commercial.lifefitness.com/resources/content/4/9/7/3/documents/95Te%20Console%20User%20Manual.pdf
2answers
"I get an error "Error in the back shading motor (4431) and the scanner stops. How can I fix it?
This error can be caused by a mechanical problem during the return of the shade. After many attempts, problem was fixed cutting both springs from pressure roll behind reading unit. The amount of spring removed changed from machine to machine. I cut 1 quarter of turn from spring and test the scanner. Procedure was repeated until problem was fixed. In worst scenario 2 turns were cutted. Be aware that cutting these springs will affect the scanned image quality.
When I plug in my walkman it reads "The player
Hi debandeba131...
Try this solution to your problem.
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
1helpful
When i turn on my phone, the screen becomes white and it shows which read " JVM error 192" in the next line it only shows which read " reset" Moreover, I had been getting low...
JVM errors are caused by the corruption of Blackberry handheld software.You'll have to reload the Blackberry handheld Software using Blackberry Desktop Manager.
Feb 22, 2011 • Cell Phones
2helpful
My unit screen reads "Replace
I don't think clearing the counters will work for the imaging unit. Just like the toner cartridges, as each time the printer is used, it ticks off another count off the chip. And when the chip reaches full count, you will need to replace the imaging unit.
The screen reads "unit immobilized
To Get to the manager and check for disabled items.
To enter the Systems Options Menu:
1. Press SELECT WORKOUT.
2. Touch the Life Fitness logo in the upper right hand corner of the screen three consecutive times
go to configuration
Configuration
Allows authorized personnel to access all configurable settings of the unit. Configurations which should only be changed by qualified technicians are password protected.
Manager Vivo/Network
Manufacturer , Create Your Own
Media Center , Clock
Custom Workouts
Touch Screen Configuration
Export / Import Settings
The console manual will show you all the default values .
https://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=483177&name=DLFE-28306.pdf
After loading a game...the screen says "reading"
Same it could be a disk tray failureapparently and they cost a bomb to fix
My dvd writer can read cd ,but cannot read dvd. I need your help to fix my problem. thank you very much.
Go to the device manager of the pc, and uninstall the unit. Reboot, and Windows will reinstall the unit. If this does not work the unit may be faulty.
How to get to the device manager:
Right click om my computer, properties hardware tab, in the middel of that screen click on device manager.
Good Luck
1helpful
Where can i find my freelander immobilizer?
your immob is in three parts, engine ecu talks to central control unit behind fuse board that inturn talks to the alarm rfd unit under dash inthe middle. all can be reprogramed but only as a complete ie all three units can also de chiped to remove both alarm and immob, allowing other make security.there are a few companies here in uk that can offer that service and new fobs.
No working good
First delete dvd device from the Device manager.
just type DEVMGMT.MSC in run command.
then delete DVD Device
after that restart the system.
if not solve then follow next step ;-
If the drives are still listed in the Device Manager, delete them then carefully follow this fix:
"Upper/Lower Filters:
a. Click on Start --> Run --> and type in 'regedit' followed by the enter key
b. Expand the "HKEY_LOCAL_MACHINE" key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
c. Expand the "SYSTEM" Key
d. Expand the "CurrentControlSet" Key
e. Expand the "Control" Key
f. Expand the "Class" Key
g. Look for a key containing the following string of letter and numbers:
{4D36E965-E325-11CE-BFC1-08002BE10318}
h. Highlight this key by left clicking once on it
i. On the right hand side you are looking for "UpperFilters" and "LowerFilters" under the "Name" column, once you find these delete them by right clicking on them and choosing "delete"
j. Exit the registry by clicking on the "X" in the top right hand corner of the screen
restart the system.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
