Here are the instructions that came with my clock.
Hi Jim, I can't read your instruction sheet. Would you be able to send me a higher resolution scan at all? [email protected]
If you would please send me a higher resolution scan of those instructions I' would greatly appreciate it. [email protected]
could i get a better copy too? [email protected]
I would like a copy also [email protected]
Hi Jim, I can't read your instructions . Would you be able to send me a higher resolution scan at all? [email protected]
Me, too? [email protected]
Hey - me also - pretty please?
Me again! [email protected]
Wow....how did you get an instruction sheet and I didn't. Would love to see a copy myself that I can read please. [email protected]
Trying to figure out how to change from C (Celsius) to F
Instruction sheet can be found at: http://www.gnbiusa.com/assets/1/7/CL-266...
I can't see where it shows how to change from C to F on the sheet.
Bravo to Adam583. The instruction sheet is there (Mar 2014) and is legible and helpful!
To change from 24-hour mode to 12-hour mode, hold the "UP" button for 3 seconds.
First you have to get it in the "Time Mode" by:
Press and hold MODE button for 3 sec. It is in the Time Mode when the hour digits begins to blink.
Next, change the 12/24 Hr. Format: In the Time Mode, press and hold the UP button for 3 sec. This is supposed to switch the 24 hr format to 12 hr format. However, I found that it does not do that but just starts to increase the hour digits from 1 to 24 over and over again as long as you press the UP button. I was not able to change my clock until I started randomly pressing all the buttons in various sequences and eventually it switched to 12 hr time. I don't know what finally did it. One problem is if you are doing this in the morning you will not see any change so try it when it is 13 o'clock or greater. Good Luck
In the process the clock switched the day of the week from Wed to Thur and now I can't get it back to Wed and there are no directions for Day of the Week function.
Anne, press the mode button (but do not hold it) and it should switch to date. While in date, press and hold mode.This should bring you to flashing year. Use up or down to adjust year, then press (but do not hold) mode and that should take you to flashing date. Use up or down to adjust date and that should set day automatically. Press mode to exit.
Travel alarm clocks can have varying
instructions, depending on the type of clock you are using. Here are
some tips for use that will apply to any alarm clock.
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
how about the other features, does anyone think it silly of a promotion like this to not come with instructions? No wonder Time is on its last legs.
instructions attached 2 pages /Users/tomcorell/Desktop/Ultronic Multi function Instructions.jpg /Users/tomcorell/Desktop/Ultronic Multi function Instructions-1.jpg
that did not work!
Found this link and it worked for me regarding the same weather clock you mentioned above:http://www.akaqa.com/question/q191921555...
This link has step-by-step instructions: http://www.gnbiusa.com/assets/1/7/CL-266...
Monica Kopecky---Adam583--Thanks, Verle Coleman
ultronic clock off milhitary time
