Fishman Matrix Infinity Acoustic Pickup Narrow Guitar Pickup Logo
Posted on May 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting hum through the speaker but when i put my hand on the jack socket it stops
Anonymous
Level 2:
Novelist:
  • Expert 82 Answers
  • Posted on May 16, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
82
Questions
0
Helped
28029
Points
250
Sounds to me like you have the connections backwards on the preamp module. Look at these connections. If you have the installation instructions, be sure the SIGNAL wire is connected to the terminal marked IN. The shield wire connects to GROUND (GRD). If you don't have the instructions you can see them and download them at http://www.fishman.com/files/matrix_infinity_preamp_installation_guide.PDF.
If that is not the problem, look at the cable you are using to connect to the amp. It has to be a standard shielded guitar cable.
Feel free to ask more questions if you need to.
Good luck. Thanks for using FixYa.
Gaker
Steve Allison
Level 3:
  • Fishman Master 5,569 Answers
Steve Allison
Fishman Master
Level 3:
Answers
5569
Questions
Helped
2002620
Points
16452
If you are in the US, take a length of light-gauge wire (AWG 20-24) attach it to the center screw that keeps the cover on over the standard dual AC receptacle and to a screw on the back of your unit. This kind of problem often is caused by a poor grounding of the cover or chassis.
2answers
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
I have an ibanez tone blaster,the lights and all come on but no sound is made. Can anyone tell me what might be the problem?
Some hopefully easy fixes : Input jack could be the problem, or connection from the amp to the speaker. Does the speaker hum a bit with the volume up almost all of the way without anything plugged into the unit? If not, check the connection from speaker to amp.
If it does hum slightly when u crank the volume, check your input jack -- it might be jacked up (pardon the pun) and you can fix that easily by soldering in a new one.
2answers
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
My Epiphone Dot just started humming really loudly when I plug it in - it stops humming when I touch the input jack. I assume it's a grounding issue on the input jack, but how do I get at...
Make you a hook out of a coat hanger. Get inside and hook the wiring to the jack, take the nut off the jack and pull it up through the F hole. You can plug in to it a patch cord so you can pull it back through once fixed. Check out Guitarelectronics.com for a wiring diagram.
1helpful
My amp isn't producing any sound. It works when headphones are in but that's it. Please help
The headphones socket is on the preamp stage - it works so the problem must be after the pre-amp.
Do you get any sound at all from the speakers (hiss or perhaps a click) when you turn it on?
If yes it is an amplifier problem.
Here are some possible causes
  • A wire has come off the loudspeaker - easy to fix
  • Speaker protection fuse has blown - small glass fuse mounted on main amplifier chassis - replace with correct rated and type of fuse (note some of these are 'slow' blow type - important that you get the right one)
  • faulty component in the main amplifier stage - requires attention from qualified repairer
  • Loudspeaker burnt out - this can be tested by connecting another speaker across the terminals of the built in speaker.
  • The headphone jack socket automatically disconnects the loudspeaker when phones are plugged in - it could be that the contact in the headphone jack socket is bent and not re-making contact when the headphones are unplugged.
When I turn on the amp, I get a loud hum. plugging into the jack doesn't change anything. turning the dials doesn't change anything. when I turn off the amp it makes a loud crack.
i) Disconnect one lead of loudspeaker & insert an open-ended guitar cable into headphone socket.
ii) Put a dc voltmeter across open end jack then turn Frontman ON for a few seconds.
iii) The reading should be about 0volts - if the voltage is high (27v), then it is likely that the PA chip TDA1514A has blown.
iv) If,however, the voltage is correct in iii) , then reconnect speaker & put guitar cable into the POWER AMP IN socket & connect other end to guitar...Turn on briefly, if there is still hum then fault is in the output stages & will require chassis removal to solve.
1helpful
Marshall AVT20X hums and no sound from the input jack (speaker voltage during humming is 13vDC)
Likely one half of the full-wave rectifier has failed. Take in for repair. Sometimes output amp shorts to one power rail causing this. DO NOT continue to operate this until repaired as it will destroy the speaker!!!
2answers
I have a djm 400and a pair of active behringer speakers model b2031a an im gettin no output from then what am i doin wrong the leads are male to female in the back of the speakers an obviosly like a phone...
First, we need to get the terminology correct.
The DJM has "PHONO" (RCA) jacks, not "phone jacks" of which the current usage is normally the 1/4 inch diameter.
You would be going INTO the Berhinger 1/4 inch jacks on the back of the speakers since you are not using the three pin XLR connections that are used for balanced lines which the DJM does NOT have.
So you should have RCA plugs to 1/4 inch plug cables. The inputs on the 1/4 inch will take TRS connections. IT IS possible you may need to use an RCA to TRS cable with the signal on the "ring" rather than the "tip" of the connector.
A test of the speakers is to touch the tip of the RCA plug with the speaker on and you should hear a hum.
PLEASE be aware that these speakers are INTENDED for use as studio monitors by the sound man in the booth and NOT for playing loud at a venue for dancers, etc.
Top Fishman Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Fishman Music Expert? Answer questions, earn points and help others
