HP Laserjet Cp2025n Printer Logo
Posted on May 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, i have cp2025 printer and it giving an error 58.04 could you please help thanks
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 218 Answers
  • Posted on May 12, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
218
Questions
0
Helped
41940
Points
680
Solution or Workaround:
NOTE: Replace the low voltage power supply before replacing the fuser or fuser power supply.
A firmware upgrade is available on www.hp.com that will solve this issue.
If the error will not clear after the firmware upgrade, replace the low voltage power supply.
If the error continues, replace the fuser power supply.
If the error still continues, replace the fuser.
Cause:
Low voltage power supply malfunction.
I hope this information helps
How to reset and/or clear error message on an hp cp2025
This sounds like bad jetdirect card causing it..problem is new HPs have them integrated and they can not be replaced. If a firmware update does not fix it, then a call to HP would be the best bet
2helpful
Hp color laserjet cp2025 10.1000 supply memory error
Hp color laser jet cp2025 10.1000 supply memory error solution
Dear Expert, I Have a new HP Colour Laserjet Printer CP2025,after Powering on there is a Error message 59.80.What could be the possible problem for this message.Please advise. Thanks and regards.
This indicates that there is a main motor error.
First check that all the toner cartridges are ok by removing them and then rotate gearing on toner cartridge just a small way to see that it is not stuck. I have found generic cartridges do seize at times and this could give the error.
Also remove fuser assembly and turn the gearing to make sure that is ok.
If all of the above are ok, then you have a defective main motor.
I have a printer HP CP2025, it gives me the follwoing Error 58.04. What I can do ?
Cause:
I install a HP color laserjet CP2025 printer occording to the manual but i got a error like (58.04 error turn off then on)and i did but it become again.so plz help thanks
This is a low voltage power supply problem. If this is a new unit, you should return it. I don't this that this problem will go away on it's own, or that it is somenthign that you cna fix.
1helpful
Printer CP2025 error - rear door open. Any suggestions please?
Are you sure that the rear door is not open? There is a door in the rear for jam clearance. Your manual can help you if you can't find this door. Manuals are on line at hp.com if you have lost yours.
15helpful
HP Color Laser Jet CP2025. Replace Supplies message on screen and can't get it off. Put in a new print cartridge. Message still won't go away. Please advise how I can get a User Manual for this...
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
2helpful
Printer model HP Laserjet CP2025, at display panel appear 'supply memory error'. How to solve it. Thank you
This is a problem with the toner cartridge, check the code at the end of the error message and that will tell you which toner is defective.
Al
k24674
Grand Canyon Tech
Grand Canyon Tech
