Which plug did you change? "EP" stands for Extended Play. A VHS recorder has three speeds. EP is the slowest. A standard 2-hour tape will record for 2 hours at the highest speed (SP), 4 hours at the middle speed (SP) and 6 hours in EP. There is a trade off. The faster the tape moves past the recording/playback heads, the higher the picture quality and visa versa. So EP gives you long recording time at a cost in quality.
I doubt that the unit being in EP mode has anything to do with the cable. You did not say what brand and model recorder you have, but in general, the speed is adjusted with a switch on the front panel (older models) or via your remote control.
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
In a VCR SP which stands for standard play on an E180 tape will last for 3 hours. So you can record 3 hours on it and much longer in EP however the quality of the picture will be less.
However I suspect that you could mean a DVD recorder. In which case a 4.7GB disc will last for 120 minutes on SP and 240 minutes on EP. Again there will be a loss of picture quality on the longer setting, but most people can cope with that.
Most VCR's have a default recording setting for recording speed or other settings. It's just a question of finding the right menu. Have a good look around the menus. However the VCR might default to SP after recording in EP, however the playback should switch to EP when playing.
I alreay figured it out on my own! However, if you'd like to pay me the "premium" price maybe I could help you out. What a joke this site is. Anyone who pays for simple advice to a site like yours is a ****** or really has no knowledge of the internet that you scam their money out of them. What a deal, the general public answers all your questions for you and a couple of A-Holes collect all the money. Scum Bags!
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
I assume by "last longer" you mean more record/play time. The slp mode is the slower tape speed, which means longer record/play time. The trade-off with the slower speed is poorer video quality.
As regards tape life, if this is what you mean- I don't know- tape life is often a matter of the quality of the tape itself.
Most late VCRs of the last 10+ years had just basic operating functions with the VCR mounted buttons. Setup of timed recording, and other advanced functions require a remote box, either the manufacturer original, or a universal unit which specifically is able to do advanced. Not all universal units have that capability, so if you go to your local electronics store, check this out carefully.
Manufacturer remotes are available: Look here- http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6711R1N051A
Zenith may offer their own universal remotes- again, check them out for the capabilities required.
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
