Hi my nilfisk alto e140.1 has just cut out i have changed the fuse its not that could someone please help because i have borrowed it off a friend :( helen....
Hi Helen,
I checked the owners manual. Here are some things you can check:
The thermal sensor has shut it down. The manual says to let it cool down for 5 plus minutes, then try it again. I imagine you've tried that already, so ....
The nozzle could be partially blocked. The nozzle MUST be detached in order to clean it. Use something as long as the nozzle, like a stiff wire or needle like object, to clear it. Then flush it backwards with water.
Since the fuse blew, try the machine without the extensions hose or use a little higher rated fuse or both.
The pump/spray gun is leaking.
If none of these works, please reply back.
I hope this does work. If it does, I'd appreciate your vote. Thanks,
Handie Andie
