umm....total series of blinks is 20, but after watching the blinks, the light just comes on, goes off, comes on, goes off. Not even a glimps of a double or triple blink. In your experience, is this a common problem with this television?umm....total series of blinks is 20, but after watching the blinks, the light just comes on, goes off, comes on, goes off. Not even a glimps of a double or triple blink. In your experience, is this a common problem with this television?
I appreciate your help. I think I'm just going to call someone out before I end up throwing a brink throgh the front if it. Thanks again for everything.I appreciate your help. I think I'm just going to call someone out before I end up throwing a brink throgh the front if it. Thanks again for everything.
You can't post conmments that contain an email address.
Thats not a valid error code for mitsubishi.It should blink a series of blinks, for the first digit then pause very briefly then blink another series of blinks for the second digit.
you will need to watch real close as it should blink a series of single blinks, then pause very briefly then blink another series of single blinks.you will need to watch real close as it should blink a series of single blinks, then pause very briefly then blink another series of single blinks.
The dm power board is the small board shown in the illustration below it has the 7 capacitors on it and its located inside the metal box on the far left side of the TV when looking in the rear cover. The metal box stands up vertically
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
The WS-100 is a floor standing speaker, and they are equipped with polycarbonate bases, attached right out of the box for ease of setup, providing a secure stable speaker system.For the price you paid I would not risk wall mount but if they must be eleveate I suggust a mounting shelve then the speakers ontop (shelves must hold speaker weight)
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Did you push in the device and the menu buttons at the same time and get the error code... I have the same problem and I get a 1,2 code.... I am looking for what the codes stand for...
Have you got any help on this....
Scott
mu email is [email protected]
