Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
