There are several reasons why your T2 Direct Dehum 3 dehumidifier may be alarming after running for a few seconds:
- Dirty or Clogged Air Filter: A dirty or clogged air filter can cause the dehumidifier to overheat and shut down. Check the air filter and clean or replace it if necessary.
- Defective Humidity Sensor: If the humidity sensor is defective, it may cause the dehumidifier to shut down. The sensor may need to be replaced.
- Faulty Compressor: A faulty compressor can cause the dehumidifier to shut down after running for a short time. You may need to replace the compressor.
- Low Refrigerant Charge: If the refrigerant charge is low, it can cause the dehumidifier to shut down. You may need to recharge the refrigerant.
- Faulty Control Board: A faulty control board can cause the dehumidifier to shut down or display error messages. You may need to replace the control board.
It is recommended to contact a qualified technician to diagnose and repair the issue with your dehumidifier.
It will not shut OFF automatically or you can't manually turn it OFF?
it will not shut off automatically
