You did not mention the new computer model but I suspect it may have an onboard audio card.You'll need to go into bios and DISABLE the onboard sound card.Reboot and it should see your new card.Hope that helps
Could you kindly explain to me how to to so step by step please?
and yes , there is a onboard audio card on the mother board , sadly i have no idea what mother card it is :/
ok this will be easy.Start the computer and while it is booting up press f2 or f8 depending on the bios.You should see something during the bootup asking to press a key (likre f1,f2)if you want to enter bios. Follow those instructions and you will enter bios.Depending on the bios setup it will differ from computer to computer.You will see tabs you can select .I want you to select a tab one at at time and look at the options given you for each page.What you are looking for is a selection for onboard sound card.You will only have the option to enable or disable.Disable the onboard sound..Find the tab to exit .It will ask you to save or not save.Select save.DO NOT tinker with any other settings as BIOS is actually the brains of your computer.(Software is like going to school and learning.) If you are in doubt of something that happened you can select not to save.
Next be sure the audio card is installed and reboot and it should see the new audio card.What you have here is a irq conflict..Stay in touch and let me know as this is easy.If your in the usa I would be willing to call you and step you through.Hope this helps
Move the card to a different pci slot on the motherboard. It may have a conflict with another device. Make sure there is no power to the pc when you do this. If you still have the problem after trying all the slots then i suggest you empty all of them and just try the audio card on its own. If it works then fit the card/s you removed into other slots. good luck.
i have the graphics card attached to one of the slots , will something happen if i try to unplug it and turn the computer with just the soundcard , plus i went to the device manager no soundcard detected !
depending on the age of the machine. I would think the graphics card is on a pci express slot or an agp slot. I am referring to just an ordanary pci slot. You may have 2 or 4 of them. what is the model of motherboard? And what is the model number SB---- of the sound card?
the mother board is asus P5QPL-AM and the model of my sound card is SB0570
It will not be a bios issue as it worked in xp and will not in Win7. It may also be that your windows 7 is the 64 bit version and you are installing the 32bit version. Make sure the driver you are using is the right one for the right version of win 7 you are using. However I cannot understand why the card is not being detecting on boot up. It should?
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight. http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html This is an updated driver release for Creative Sound Blaster PCI128 for Windows NT only http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html The driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added.
http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmln This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
