20 Most Recent Creative Labs SB0100 Sound Card Questions & Answers
2answers
Driver for soundblaster eureka pci 64 soundcard
I found one on a search I did for you, and it's here
http://ccfiles.creative.com/manualdn/Drivers/Others/265/e64w9xup.exe
I believe fro looking at the link it is for 98 on up, take a look, and please no raing is worse than a 2 or 3, so if I haven't helped you please don't give me any rating at all, as it is the way we are compensated, thanks,and Merry Christmas
1/23/2018 4:40:30 PM • Creative Labs... • Answered on Jan 23, 2018
0answers
6answers
Sound Blaster SB0100 drivers wanted.
for anything past xp you have to use software called the kx project which is for 30 and 64 bit vista and windows 7 drivers will work every time creative does not have posting past xp drivers the cards to old but its an oldie but a goody hope that helps
10/6/2012 3:23:05 AM • Creative Labs... • Answered on Oct 06, 2012
A don't known
if its the drivers you require
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10005159.html
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-sound-blaster-audigy/3000-2120_4-10198811.html
http://download.cnet.com/%7Bvalue=http://www.download.com/creative-labs-sound-blaster/3000-2120_4-10022925.html http://www.boxdrivers.com
using this link you will be able select your drivers
if these sound driver packages are not right http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for (be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope one of these will help you
9/18/2011 8:21:52 PM • Creative Labs... • Answered on Sep 18, 2011
2answers
My creative sound blaster SB
First install the chipset driver.
Then install the audio driver. Your computer will detect your sound blaster.
I've not...
Make sure you are using the right driver
6/6/2011 1:00:32 PM • Creative Labs... • Answered on Jun 06, 2011
Sound no
The first step is to make sure that the device is working properly, and the drivers for it are installed. right click on 'my computer' or 'computer' in the start menu, then click properties, then look for device manager. you will see a list of all the hardware in your computer in a collapsible menu. go down to sound video and game controllers and look to make sure your sound blaster is listed there, and that there is not a yellow '?' or '!' over the icon next to it.
If the device is listed there and has no errors on it, the next thing to check is to make sure it is not muted, click the speaker in the bottom right hand corner of your screen and go to mixer, make sure that the little image of a speaker below each volume slider is not crossed out.
failing these options, it could be a problem with your speakers, remove the plug from the green socket on the back of the sound card, and plug in a set of headphones in its place, see if you get any sound that way.
5/29/2011 5:10:39 AM • Creative Labs... • Answered on May 29, 2011
I can't set my creative
if you are having problems with your sound if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer make sure you have an earth ******** before touching any parts inside your computer hope this helps
5/22/2011 4:04:11 PM • Creative Labs... • Answered on May 22, 2011
Bookok
5/15/2011 4:41:15 AM • Creative Labs... • Answered on May 15, 2011
Sound card
5/14/2011 5:37:18 PM • Creative Labs... • Answered on May 14, 2011
2answers
I need the driver creative labs sb0090
try to download it at www.driverguide.com
4/26/2011 2:29:56 PM • Creative Labs... • Answered on Apr 26, 2011
I have a sound card
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers cnetdowload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html Realtek AC
4/25/2011 9:11:10 AM • Creative Labs... • Answered on Apr 25, 2011
Sound Blaster Live! 5.1 (W7)
This should be the appropriate page to find the driver (halfway down):
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=206&prodID=4857&prodName=Sound%20Blaster%20Live!&subCatName=Live!&CatName=Sound+Blaster&VARSET=prodfaq:PRODFAQ_4857,VARSET=CategoryID:1
You can also just start the whole process from the beginning at support.creative.com
4/18/2011 8:50:05 PM • Creative Labs... • Answered on Apr 18, 2011
5answers
I NEED DRIVERS FOR SOUNDBLASTER
http://support.creative.com/Downloads/searchdownloads.aspx?filename=SB24_PCDRV_LB_1_04_0090.exe
there ya go let me know if that helped
3/20/2011 6:19:27 PM • Creative Labs... • Answered on Mar 20, 2011
I need up date for
2/4/2011 5:43:39 AM • Creative Labs... • Answered on Feb 04, 2011
Creative Labs SB0100 Sound Card Logo
68 questions posted
Top Creative Labs Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Creative Labs Computers & Internet
Most Popular Question
need soundblaster live 5 1
  • Computers & Internet
