While
you forgot
windows
os password, you
can enter
safe mode (F8 when booting up) to recover
windows password while
you forgot
user account password, but
when you forgot admin
passwords,
there's
no way to change it, you should
use utility
to recover admin
password. Last
week, I forgot my Windows admin
password. Last,
I
used Windows Password Seeker to remove
the
Windows password successfully. It's worth an
attempt.
http://www.passwordseeker.com
Forgot Windows XP Password? ' The Best Way To Recover Lost XP Password!
Forgot Windows XP Password? The first thing which you check is whether you forgot windows xp login password or not. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forgot your user account password then try this:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
Windows XP and further versions also provide another method to recover forgotten Password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. Or try free program called Ophcrack or Windows Password Recovery Tool 3.0.
More detail guide on: http://www.windowspasswordsrecovery.com/bypass-xp-password-in-safe-mode.htm
When you forgot Windows XP password and want to hack Windows XP password at any time, no hesitate to make use of SmartKey Windows Password Recovery. The same as Windows 8 password recovery tips.
Step 1: Download and install, run the program on a unlocked computer.
Step 2: Burn a bootable CD/DVD/USB Flash Drive with the program.
Step 3: Reset Windows password by the burned CD/DVD/USB Flash Drive.
Now it has promotion until Jan 15th,2013
http://www.recoverlostpassword.com/promotion/christmas.html
You can hack it with windows password tool. In order to avoid data loss on the computer, I recommend Windows Password Reset 9.0. Few days ago, I downloaded it at http://www.reset-windows-password.com/how-to-reset-windows-password.html I burned it to a Usb memory card. Boot up and cleared my password successfully.
You can remove it with windows 7 password tools. For removing Windows login Passwords safely, I strongly recommend Windows Password Reset 9.0. Few days ago, I downloaded it at http://www.reset-windows-password.com/reset-windows-7-password.html I burned it to a Usb memory card. Booting up and clearing my password within just 5 minutes.
I know a website http://www.reset-windows-password.com there are a lot of softwares on it, you can download one to reset or remove your windows password. it is compatible with Windows 7.
Remove/hack Windows password you can use Windows Password Rescuer, it can reset/remove Windows 7/vista/xp/2008/2003/2000 password instantly.
I highly recommend [Daos Password Recovery Bundle 2012].[Daos Password Recovery Bundle 2012] is an all-in-one password recovery software, which recover password for Windows, Excel, Word, Access, PowerPoint, Outlook, RAR/WinRAR, ZIP/WinZIP, PDF etc. Over 70+ types of passwords can be recovered instantly.
Hack windows password you can download a windows password tool, I think windows password seeker is the best one. You can have a try.
If you have forgotten it, the only way to reset your admin password in xp is to reinstall windows
