20 Most Recent
Dell Inspiron 531S (DDCWGA1_5) PC Desktop Questions & Answers
How do i unlock my dell pc password
start your system when windows welcome screen appear press ctrl+alt+delete keys twicw it will show you login classic window then press\ administrator\ in user name and password left all blank and press enter u can login.now you can reset using control panel -user password.2nd method is window password recovery method tool 3.0
Sound is distorted
Speakers may be blown. Try another set of speakers on the computer or try the speakers on another computer to isolate the problem.
Where do i find my
Normally you will be able to see it from the back of your computer. The part you can see from the outside is usually about half an inch high by 4 inches wide. They usually have a stubby little antenna sticking out, or at least an antenna screw in jack kinda like the one on the back of your tv except smaller.
If you want to see the whole thing or remove it, you will have to remove the side panel from your case (usually 2 screws on back holding it on).
Then there will probably be 1 screw holding the actual wireless card in place inside at the back. Once that screw is removed you can just pull it straight out of the motherboard socket.
Obviously you would unplug the power cable and the monitor cable before you open up the case to prevent any shock to yourself or damage to your machine.
Go to EBAY.COM and search for "desktop wireless card" and you will see a bunch of different pictures of them.
Good luck and post back if this was helpful at all.
I have an Dell inspiron
It sounds like it is confused and has lost some of the registry entries, like we would have an index to find the files. Hopefully they are all still there.
Press F8 as it boots up, this should get you into a sub menu that allows you to use Safe Mode or Recovery. Try safe mode first as Windows will search for the "missing" files and repair the registry. If that doesn't work try Recover and follow the prompts. (That may only work under F11).
Hope that fixes it.
How do I get into safe mode on a Dell Inspiron
You cant get in safe mode because the PC hangs before windows ever try to start.
Try to press F8 multiple times but right after the Dell screen.
Some computer don't like that you press F8 while the bios is loading and just hangs there, maybe its your case.
How do i reboot my inspiron 531s
Also if your ram is to low it may not have enough memory.Also do a disk clean and defrag if you get on there and remove any programs not being used hope i helped:)
Dell Inspiron 531S "windows failed to start"
Well the recovery disk are not bootable if you changed the routeing order okay this would be a little invasive take the hard drive out of the computer and reformat it in another computer if another computer is not the option then your going to need to take it in to a computer repair shop there is nothing we can do online that you can do there because we cannot communicate to you outside of fixya.com realm I cannot even send you anything without getting in trouble. I hope this helps. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Lost my XP Admin name and password. So how do I hack it?
well hacking is illegal wether it is your own system or not i can not confirm.
best advise i can give you is see if the administrator account is on.
wich would most likely be :
username : Administrator
password :
yes password would be nothing.
if it works you can reset your password of your own account
good luck
How to play movies from computer on tv?
if your tv has vga in, then you need a vga to vga cable (like a screen wire) then change the resolution in the settings of windows (put 800X640 resolution before you plug tv so that you can know what is supported)
if it doesent then you cant do anything other than buying a video card with hdmi or dvi (with a dvi to hdmi) with a hdmi cable then plug it in (will auto detect)
Cd/dvd drawer on Dell inspiron 531S will not go back in
It would be best to replace the drive unless you feel comfortable dissasembling it to clean out the gears that drive the tray. If you are able to look in the drive at all you might look to see if the "eye" popped up before the tray retracted all the way if so you might be able to manually push it back down and also just give a quick look at the exterior to see if the tray is caught up on anything and also look to see that it is moving in/out straght.
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
