SOURCE: Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance. Donald McPherson Certified Watchmaker AWCI www.finewatchmaking.com
SOURCE: Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
SOURCE: the winding stem came out when i was trying to set time formula 1
I would advise you to take it to an authorised dealer (see the Tag Heuer web site (www.tagheuer.com) ) and let them sort out why the stem came out. I feel sure that this shouldn't happen and it is likely that a repair is needed.
(It may be that something that restricts the movement of the stem has become detached. If this is so, then something may be moving about inside).
