SOURCE: Eureka Wide Track Superlite
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12164&thid=669867
Posted by mjtnm on Jun 14, 2008
The brush motor went out. Is it possible to buy one and splice it to the existing wires? Where can I buy one? The vacuum is model #409 the number on the dead motor is: DA-20L-2001, 17.5V DC AOM 4293S
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 421A EZ Kleen Bagless Stick Vacuum. Yes, you can replace the power nozzle motor in the head of the Eureka 421A EZ Kleen Bagless Stick Vacuum by either contacting the local vacuum cleaner dealer in your area or to contact the Eureka factory and ask for cust serv or tech support or parts and they will direct you to the correct dept to order the P/N motor so that you can install it and get on with your cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Motor overheating
Had the same problem 2 years ago. Washing filters only a short-term solution. After contacting Dyson, they replaced the shroud and cyclone under warranty. This cured the problem from July 05 until last week, when the motor has started to overheat again and cuts out on the high temperature safety trip. Mine is out of warranty now, so am unsure how to proceed. Maybe buy the parts they sent me before, but reckon they'll be expensive.
SOURCE: Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
SOURCE: Eureka Wide Track Superlite Vacuum
Eureka doesn't make these motors available. Best to just replace the stick vac with a new one.
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
