Please try 0863 for Hyundai Televisions
To program your Sky remote control using the 4 digit code
If
the TV does not go into standby press the TV button then the standby
button, then TV then standby, keep repeating this until successful. This
will scan the codes used for a particular make of TV. Please keep me posted. Thanks. Lor04
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
thanks to all you are brilliant
