Bosch MCM5100 Food Processor Logo
Posted on Apr 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor is working but blade is not moving - Bosch MCM5100 Food Processor
Janarthanam Thirunavukarasu
Level 2:
Guru:
  • Expert 230 Answers
  • Posted on Apr 05, 2011
Expert
Level 2:
Guru:
Answers
230
Questions
0
Helped
51145
Points
383
Rubber bush might be worn out
Cuisinart Mini prep plus: blade turns when there is no food to chop, but when there is, blade does not turn even though motor is running
SOLVED: Why won't my blades turn? - Oster Blend-N-Go My Blend - iFixit
https://www.ifixit.com/Answers/View/259808/Why+won't+my+blades+turn
Oct 1, 2015 - The blades may not be turning because the blade assembly is not fully ... Blades do not turn but the motor runs. ... this is a touch and go motor so it is easy to start the motor withoutproperly ... The blade should turn, if not they need to be replaced. ... My blender isn't even a year old and blades wouldn't turn. Why is my Magic Bullet just humming, but the blades ...
1 answer
Oct 29, 2015
Why are the blender blades not rotating? - Ninja NJ600
Apr 30, 2015
More results from www.ifixit.com
2answers
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Can't remove the container from the motor housing
It will be the blade holding the bowl on. The blade has become locked onto the motor shaft, in the end you are going to need to replace both. Take it to a K/A service agent.
11helpful
3answers
I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
Cuisinart mini prep processor blade not rotating
Replace work bowl and blade - see if it resolves the issue.
Top Bosch Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you a Bosch Food Processor Expert? Answer questions, earn points and help others
