20 Most Recent
Bosch MCM5200 Food Processor Questions & Answers
Can you tell me what to check on my food processor?
It sounds like the safety mechanism is fussy. It may be broken. Or, sometimes a connection within the unit itself might come loose. I've seen wires get so hot the solder melts and the wires detatch. The little tab that engages the safety mechanism might be chipped or broken off. If the outlet is working, the unit is getting power. The power is just not getting to the motor inside the device.There could be an internal fuse that blew. If you unplug the device, set it up as if you are going to use it, activate the the device while holding an ohmmeter to the plug prongs, you should get a reading over 10 ohms. If you get 0 ohms, there's and internal short circuit. If you get nothing--overload--infinite, it's a loose connection or a blown internal fuse.
