20 Most Recent
KitchenAid KFP750 Food Processor Questions & Answers
Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Motor won't start when bowl locked in position
Hi, I had the same problem with my KitchenAid KFP740. The fix was the handle cap was loose. We all have a tendency to lift the unit out of the cabinet by the handle and it is heavy! The handle has a mechanism inside. The outside piece of the handle that holds it all inside gets loose making the pin at the bottom of the bowl not reach where it needs to be when you put the lid on. If you assemble the unit and squeeze the top of the handle after you put the lid on mine would work. A little gorilla glue and I was back in business!
Closing the lid completely the processor does not work
Take everything off and see if you can activate the motor with the safety switch. It is located at the front above the button panel normally covered by the working bowl. Mixer plugged in and turned on press that button switch in with something non metallic. If the motor goes then fault will be with the mechanisms that activate that switch in either the bowl or the lid. The lids are slightly more likely to be the problem than the bowl. Only a new part will properly solve it.
The stem is stuck on kitchenaid kfpw760
The motor shaft sleeve and spindle will need to be replaced, once this jamming has happened it becomes ongoing if you do not replace those inexpensive parts. You need to wrap some webbing tightly around the spindle attach the other end to something very solid (like a fence post) and then accelerate the motor part rapidly away from the post. Hold onto the motor very firmly or it will land on the ground.The webbing tightens instantly when it runs out of slack and the spindle will come off. Then you need to remove the motor shaft sleeve in a similar manner, I drill a hole in the end and use a shackle and chain attached to the post for that one. I use the leg of my workshop bench, most folks will not have a solid heavy bench like mine. If that sounds too hard just take it to your local K/A service agent, they will have done it many times.
Spindle jammed on the stem
How to remove motor shaft sleeve from KitchenAid
I just did this. I used a screwdriver and some needle-nose pliers to wedge and separate the shaft from the base. Once you've separated it by about 1/2 inch, it will come off easily. I simply used a mallet to install the new one.
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
