Problem
After you install a print cartridge, one of the following messages appears on the color graphics display:
NOTE:
In
the procedures below, the "problem" cartridge is the one identified by
the message on the color graphics display. If the message does not
specify a cartridge, perform the procedures on both cartridges.
Step 1: Remove, inspect, and reseat the problem cartridge
The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE:
HP cannot guarantee the quality of remanufactured or refilled cartridges.
Step 2: Clean the problem cartridge contacts
CAUTION:
Do not touch the copper electrical contacts or the ink nozzles.
Figure 2: Electrical contacts and nozzles
1 - Copper electrical contacts
2 - Nozzles
CAUTION:
Do not attempt to remove the copper electrical strip!
Figure 3: Removing the clear nozzle protective tape
Step 3: Repeat reseating and cleaning steps
If the problem is not solved, repeat the reseating and cleaning procedures above.
NOTE:
Clean
the contacts quickly so that the cartridge is not outside of the
product for more than 30 minutes. If the cartridge is outside of the
product for too long, the ink can dry and clog the nozzles.
CAUTION:
Do not touch the ink nozzles.
Call HP if the cartridge is covered under warranty to replace the cartridge
or its time for a new printer
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color. And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
