SOURCE: My Casio waveceptor tough solar watch will not pick up its signal
You may have wrong manual. Follow this link and find correct one:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
SOURCE: cannot set the time
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=4303&submit.x=63&submit.y=7
address to download a Casio manual.
SOURCE: Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
SOURCE: Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
