Follow this:First things first: DO NOT take any more recordings with the the same recorder that you want to recover files from. Then take the memory card or hard drive out of your recorder, and connect it to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Then install this software Wondershare Photo Recovery (recover videos and audio files too) on your computer. Then start to scan and see if your deleted files can be got back. Get the program from:
Remember - Do NOT try & write anything back to your digital recorder(card or disk) until you can recover your files safely! I hope you good luck! Regards
It is not possible to download the sound files in their digital forms with this model of recorder. The only way to transfer the recordings is to connect a male-to-male 3.5mm (1/8") plug from the recorder to the line input of the PC (as was formerly mentioned) and record it onto the PC in real time. I've done this with mine and it works fine...it just takes longer to do than tranferring the actual digital file to the PC. A good MP3 recorder for the PC is Audio Record Wizard. http://www.nowsmart.com/arwizard/
The full version costs $25, but I think it's worth it.
press the erase button, it should flash delete at you, if you let it do that to long it will go back to the way it was before you hit the erase button. to delete, hit erase on the folder you want then hit erase and hold it untill it deletes the file. continue this proccess untill all files are deleted
