This all started when my settings on Norton 360 werent set to scan viruses and i managed to get a Trojan Zlob, Deleted it but it has left some damage! I get a PDFDirect.exe stopped working, and the above message. I have run the following:
Webroot spy sweeper - found nothing Adware Alert - found and deleted alot of spyware and installed and ran Registry Smart - it found and repaired about 1195 registry related problems.
PROBLEMS HAVEN'T GONE AWAY THOUGH!! Any suggestions?
Did you already tried doing a system restore on the time that everything was working fine? if not yet tried doing that first and hopefully that will correct the problem but if still have the same problem you can try some anti malware software like Malwarebytes this will be helpful to you....
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found. Solve my this problem as soon as possible.
I had visited a website to get a free screen saver. somethling like a
toolbar or something was downloaded onto my computer, I used Windows
XP. Actually I was cancelled the process of download but obviously when
I was restart my computer a error message showed "Run DLL
Error loading C:\PROGRA~1\MYWEBS~1\Bar\1.bin\M3PLUGIN.DLL
the specified module could not be found
Is any suggestions as how to remove this unauthorized download from my system.
Thanks in advance
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found. pentium iii windows XP the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
I followed these steps and haven't had any issues since:
1. Go to START menu 2. Select RUN 3. Type MSCONFIG and click OK (or press ENTER) This will bring up your System Configuration Utility window. 4. Select the STARTUP tab. 5. Find M3PLUGIN, untick it, select APPLY and then OK This will bring a popup dialogue box stating the following:
"You must restart your computer for some of the changes made by System Configuration to take effect."
6. Select RESTART.
When your computer restarts, you should no longer receive that message.
